bsmokey
#1 Posted : 17 years ago
bsmokey
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It sounds as if it is coming from between the two tubs. Whats the trick to seperating the two tubs?:(
#2 Posted : 17 years ago
The first thing I would recommend to do is remove the front panel and check for water leak from the central seal.
Sounds like the problem is a bad central bearing and usually it happens when the central seal is leaking.
Inspect the washer and post your findings.
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 10 months ago
GE washer grinding noise (Washer Repair)
by gefixin 10 months ago
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2 years ago
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 2 years ago
Whirlpool Direct Drive Top Loader, grinding noise on spin start (Washer Repair)
by GRTison 3 years ago
Maytag washer mvwb300wq2 has low grinding noise and won't turn on (Washer Repair)
by mzimmerman72 3 years ago
Whirlpool wtw5000dw1 grinding and banging (Washer Repair)
by pcarlson 3 years ago
Grinding with working agitator. (Washer Repair)
by Guest 3 years ago
Whirlpool washer agitator working but with grinding noise (Washer Repair)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
Washing Machine Grinding Only in last minute of spin cycle... (Washer Repair)
by Jon_T 4 years ago
GE Profile Quiet Power 2 - grinding noise BETWEEN stages? (Dishwasher Repair)
by Guest 4 years ago
Whirlpool washer started making grinding noise (Washer Repair)
by apples99 4 years ago
Grinding noise when running. (Washer Repair)
by Donaldbain007 4 years ago
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 4 years ago
