bsmokey
#1 Posted : Thursday, November 15, 2007 6:04:05 PM(UTC)
bsmokey
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It sounds as if it is coming from between the two tubs. Whats the trick to seperating the two tubs?:(
#2 Posted : Friday, November 16, 2007 5:21:23 PM(UTC)
The first thing I would recommend to do is remove the front panel and check for water leak from the central seal.
Sounds like the problem is a bad central bearing and usually it happens when the central seal is leaking.
Inspect the washer and post your findings.
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
Whirlpool Direct Drive Top Loader, grinding noise on spin start (Washer Repair)
by GRTison 5/1/2022 4:14:53 AM(UTC)
Maytag washer mvwb300wq2 has low grinding noise and won't turn on (Washer Repair)
by mzimmerman72 4/4/2022 2:01:41 PM(UTC)
Whirlpool wtw5000dw1 grinding and banging (Washer Repair)
by pcarlson 12/26/2021 5:17:03 AM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
Washing Machine Grinding Only in last minute of spin cycle... (Washer Repair)
by Jon_T 8/21/2021 11:15:16 AM(UTC)
GE Profile Quiet Power 2 - grinding noise BETWEEN stages? (Dishwasher Repair)
by Guest 8/19/2021 1:53:26 PM(UTC)
Whirlpool washer started making grinding noise (Washer Repair)
by apples99 6/30/2021 3:29:01 PM(UTC)
Grinding noise when running. (Washer Repair)
by Donaldbain007 5/30/2021 1:13:54 PM(UTC)
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 5/29/2021 2:00:00 PM(UTC)
Whirlpool Cabrio MVWC400XW making horrible high pitched grinding noise (Washer Repair)
by kwale 3/6/2021 1:11:38 PM(UTC)
GE GFWE2700H1WW - ~2016 Frontloader - Whirring/Grinding on Spin Cycle (Washer Repair)
by SpinningInCircles 11/27/2020 10:46:56 AM(UTC)
