eljnlm
#1 Posted : Friday, February 27, 2009 9:06:08 AM(UTC)
eljnlm
The plastic trim around the door just on the hinge side has seperated from the metal clips. How do I get these clips re-attached to the plastic trim?
TechnicianBrian
#2 Posted : Friday, February 27, 2009 2:57:21 PM(UTC)
TechnicianBrian
You can try removing the panel and glue the clips back on, but you will break several more off just trying to get it removed (experience talking). Your best bet would be to replace the trim (AP4341018) as the new version has a different style clip that actually allows the trim to be removed without damage. If you do try and remove it, take the top panel off (screws along the top rear) and you can get your hands to many of the clips and squeeze them as you pull the trim away from the front panel. Enlist some help, because as you pull, the the clips already removed will start scratching the panel.
eljnlm
#3 Posted : Friday, February 27, 2009 11:48:38 PM(UTC)
eljnlm
Thank you TechnicianBrian. You are right, I can see how the clips broke away from the plastic. Thanks for the part number.
Eric
TechnicianBrian
#4 Posted : Saturday, February 28, 2009 8:28:58 AM(UTC)
TechnicianBrian
Glad I could be of assistance.
Whirlpool Duet Gas Dryer Model GGW9250PW1 Need New Board? Not Available (Dryer Repair)
by st3v3 9/24/2021 7:11:18 AM(UTC)
Whirlpool Duet Gas Dryer Model GGW9250PW1 (Dryer Repair)
by st3v3 9/24/2021 7:06:10 AM(UTC)
Whirlpool Duet Gas dryer lint screen won't fully seat (Dryer Repair)
by mzamborini 5/13/2018 6:45:20 AM(UTC)
Whirlpool Duet Gas Dryer will not stay hot (Dryer Repair)
by TheNunz 9/13/2015 4:37:13 PM(UTC)
Whirlpool Duet Gas Dryer no run, hear click after Start button but no run (Dryer Repair)
by tae 8/31/2013 6:51:36 PM(UTC)
Whirlpool Duet Gas Dryer is POSSESSED! (Dryer Repair)
by JimStinson 8/3/2013 8:32:44 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Whirlpool Duet gas dryer (Dryer Repair)
by Mad@Irene 1/21/2012 6:28:09 PM(UTC)
whirlpool duet gas dryer wont start (Dryer Repair)
by doverf 12/4/2011 1:38:25 AM(UTC)
Whirlpool Duet Gas Dryer (Dryer Repair)
by KarinaAnn 4/25/2011 10:21:19 AM(UTC)
Whirlpool Duet Gas Dryer-door won't lock (Dryer Repair)
by whacker1999 9/22/2008 10:07:46 AM(UTC)
Convert Vent - Whirlpool Duet Gas Dryer (Dryer Repair)
by hhammond 4/16/2008 4:11:12 AM(UTC)
