KarinaAnn
#1 Posted : Monday, April 25, 2011 10:21:19 AM(UTC)
KarinaAnn
The heat in my gas dryer lights up, goes out, lights up, goes out. It does not stay on long enough to heat anything, just uses up gas. I have looked at the troubleshooting guides and nothing helps. Any ideas? Or is this just not the way the dryer should work?
#2 Posted : Monday, April 25, 2011 12:17:22 PM(UTC)
The flame normally should cycle on and off, but it should stay on for about 50-60 seconds. If it stays on for a very short time, you may want to make sure the vent line is clear all the way through the vent outlet and all air ducts inside the dryer are clean.
Here are the breakdown diagrams and Replacement parts for MAYTAG NGD7500VW0 GAS DRYER | AppliancePartsPros.com
KarinaAnn
#3 Posted : Wednesday, April 27, 2011 7:43:38 AM(UTC)
KarinaAnn
Thanks Gene, I will do that right away. I did check the vent hose and it is not crimped, but I will disconnect it and look inside. Again, thanks!! Karina
#4 Posted : Wednesday, April 27, 2011 1:55:26 PM(UTC)
beavis6880
#5 Posted : Thursday, April 28, 2011 7:26:05 PM(UTC)
beavis6880
Try running the dryer with vent disconnected for a short time to see if that helps. By doing this you completely remove the venting from the equation. Make sure you have plenty of fresh air in the room since this is a gas dryer so you dont get CO poisoning.
Whirlpool Duet Gas Dryer Model GGW9250PW1 Need New Board? Not Available (Dryer Repair)
by st3v3 9/24/2021 7:11:18 AM(UTC)
Whirlpool Duet Gas Dryer Model GGW9250PW1 (Dryer Repair)
by st3v3 9/24/2021 7:06:10 AM(UTC)
Whirlpool Duet Gas dryer lint screen won't fully seat (Dryer Repair)
by mzamborini 5/13/2018 6:45:20 AM(UTC)
Whirlpool Duet Gas Dryer will not stay hot (Dryer Repair)
by TheNunz 9/13/2015 4:37:13 PM(UTC)
Whirlpool Duet Gas Dryer no run, hear click after Start button but no run (Dryer Repair)
by tae 8/31/2013 6:51:36 PM(UTC)
Whirlpool Duet Gas Dryer is POSSESSED! (Dryer Repair)
by JimStinson 8/3/2013 8:32:44 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Whirlpool Duet gas dryer (Dryer Repair)
by Mad@Irene 1/21/2012 6:28:09 PM(UTC)
whirlpool duet gas dryer wont start (Dryer Repair)
by doverf 12/4/2011 1:38:25 AM(UTC)
Whirlpool Duet Gas Dryer (Washer Repair)
by eljnlm 2/27/2009 9:06:08 AM(UTC)
Whirlpool Duet Gas Dryer-door won't lock (Dryer Repair)
by whacker1999 9/22/2008 10:07:46 AM(UTC)
Convert Vent - Whirlpool Duet Gas Dryer (Dryer Repair)
by hhammond 4/16/2008 4:11:12 AM(UTC)
