cincyfire
#1 Posted : Monday, February 23, 2009 9:51:54 AM(UTC)
cincyfire
I HAVE A GE GAS OVEN THAT ONLY THE BROILER BURNER WORKS. THE
BOTTOM BAKE BURNER WILL NOT IGNITE. IS THIS A FIX FOR A HANDY PERSON. THANKS FOR ANY HELP? :confused:
#2 Posted : Tuesday, February 24, 2009 5:32:04 PM(UTC)
Remove the bottom drawer, disconnect the Bake igniter wires and check the igniter for continuity. Replace the igniter if the circuit is open.
This job is not too difficult to do it yourself.
- The part number for the Bake igniter is AP2014008
Here are the break down diagrams for the GE range Model JGBP90MEA1BC
GE gas oven not maintaining temperature after preheat completes (Oven Repair (including Ranges and Cooktops))
by Guest 12/2/2022 7:33:59 PM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
GE GAS Oven will preheat but will not maintain set temp after reaching (Oven Repair (including Ranges and Cooktops))
by jblood98 3/11/2021 9:13:22 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
GE gas oven - broiler ignites, but not lower burner (Oven Repair (including Ranges and Cooktops))
by shortmort37 12/14/2017 6:11:01 PM(UTC)
GE Gas Oven, both burners won't light (Oven Repair (including Ranges and Cooktops))
by AlexelA 4/7/2016 9:54:33 AM(UTC)
Oven and Electronic clock stopped working on GE gas oven (Oven Repair (including Ranges and Cooktops))
by richfix 5/30/2015 6:44:26 PM(UTC)
GE Gas oven/broiler igniters glowing but gas not flowing. (burners OK) (Oven Repair (including Ranges and Cooktops))
by cbrodsky 12/10/2013 7:04:02 PM(UTC)
Burnt igniter wiring on old GE gas oven - why? (Oven Repair (including Ranges and Cooktops))
by akstens 1/4/2013 2:20:04 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
by Manopoli 5/22/2012 10:21:47 AM(UTC)
GE gas oven won't light -- igniter works (Oven Repair (including Ranges and Cooktops))
by markdraper 5/26/2011 10:37:41 AM(UTC)
GE gas oven not maintaining proper temp. (Oven Repair (including Ranges and Cooktops))
by bowflyman 1/5/2011 11:48:48 AM(UTC)
GE gas oven Broiler knob/switch malfunction (Oven Repair (including Ranges and Cooktops))
by 1consumer 7/27/2010 11:31:46 AM(UTC)
GE Gas Oven ignitor not glowing (Oven Repair (including Ranges and Cooktops))
by needhelp63 1/18/2010 6:46:49 AM(UTC)
