hbarcus
#1 Posted : Tuesday, February 3, 2009 1:22:44 PM(UTC)
hbarcus
My Amana Side-by-side is not making ice.
I replaced the ice maker as I have done before, still no ice.
The problem is that the ice maker is not filling with water.
If I manually pour water in the ice maker, it will freeze and dispense; therefore, the new ice maker is cycling.
I removed the bottom back cover and swapped the input electric connectors so that the water dispenser in the door would activate the ice maker fill solenoid. This worked and water came into the ice maker.
It seems to me that the solenoid that activates the fill valve for making ice is o.k. but is not being sent an electrical signal. I'm assuming that the electrical signal should be coming from the ice maker.
Any ideas on what to check next?
Is there a way to test the ice maker while it is out of the refrigerator?
The wiring diagram on the back of the unit indicates a fuse in the ice maker circuitry. Could that be a problem? If so, where is it to be found?
I'm mechanically oriented and would love to fix this my self if possible.
Any help would be much appreciated.
Thanks,:)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 3/7/2023 12:03:25 PM(UTC)
was making ice, since replaced water filter is not making ice (Refrigerator & Freezer Repair)
by Guest 1/29/2023 8:54:04 PM(UTC)
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 9/19/2022 9:02:45 AM(UTC)
Kitchenaid 3 door not making ice (Refrigerator & Freezer Repair)
by Guest 4/8/2022 8:04:40 AM(UTC)
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 9/3/2021 10:14:18 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Frigidaire gallery refrigerator not making ice (Dishwasher Repair)
by Matt410 5/27/2020 5:36:26 PM(UTC)
AFI2538AEB4 not making ice? (Refrigerator & Freezer Repair)
by Codysharp 5/25/2020 11:38:11 AM(UTC)
GE PGSS5RKZH SS not making ice (Refrigerator & Freezer Repair)
by mjlwood 2/18/2019 10:42:26 AM(UTC)
Whirlpool refrigerator is not making ice cubes again. (Refrigerator & Freezer Repair)
by FastEddieG 7/20/2017 11:36:26 AM(UTC)
Whirlpool ED5KVEXVB00 NOT MAKING ICE (Refrigerator & Freezer Repair)
by Ken936 6/15/2017 6:47:37 PM(UTC)
Whirlpool Not Making Ice (Refrigerator & Freezer Repair)
by wagnerlip 4/6/2017 3:55:48 PM(UTC)
