My Maytag AFI2538AEB4 is not making ice,i have power on the L and N (120v with door closed and switch on). The thermal fuse shows continuity, and I'm lost. Fan works on back of the ice maker, when I press the button it makes the auger spin. The arm that knocks the ice out of the tray isn't moving. Switch is on. I'm clueless. I could probably do more if I had a schematic. ANY ideas would be greatly appreciated!
It turned out to be a bad replacement ice maker. Once I received another replacement, it works!
