dfelske
#1 Posted : Sunday, January 11, 2009 4:19:10 PM(UTC)
dfelske
i have a glass top Kenmore range with radiant heating. The 9" burner stopped working. The wires were burnt when i looked at it. I ordered a new burner on line it is a replacement and has a different wiring schematic. I am looking for a wiring diagram for this model.
#2 Posted : Monday, January 12, 2009 4:06:25 PM(UTC)
The wiring diagram could be inside the control panel or under the top panel. If it's not there then you can order it from Sears. The Sears part number is SR13606.
Thermador cooktop burner keeps clicking after igniting (Oven Repair (including Ranges and Cooktops))
by dcdwyer 8/4/2021 10:48:09 AM(UTC)
Avoid Siamesed Jenn-Air Cooktop Burners Upon Switch Replacement (Oven Repair (including Ranges and Cooktops))
by Tigertank84 2/26/2020 10:19:47 AM(UTC)
Glass Cooktop Burner Won't Shutoff (Oven Repair (including Ranges and Cooktops))
by chris3 2/12/2019 3:25:20 PM(UTC)
GE Profile Cooktop burner and bridge not working (Oven Repair (including Ranges and Cooktops))
by captjane35 5/27/2015 10:22:00 PM(UTC)
Whirlpool cooktop burner on max only (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 11/8/2014 5:09:52 PM(UTC)
Both oven and cooktop burners work intermittently (Oven Repair (including Ranges and Cooktops))
by WmHBlair 9/12/2014 9:54:15 AM(UTC)
whirlpool cooktop burners heats slow minimum heat on all burners (Oven Repair (including Ranges and Cooktops))
by wigginscallie@yahoo,com 8/15/2013 7:09:45 PM(UTC)
Cooktop burner does not turn on (Oven Repair (including Ranges and Cooktops))
by Mesozoic 8/6/2013 2:28:53 PM(UTC)
Replacement Cooktop Burner Gas Lines (Oven Repair (including Ranges and Cooktops))
by Punchie 7/31/2013 8:33:53 AM(UTC)
Cooktop burner only high when turned on (Oven Repair (including Ranges and Cooktops))
by Mmiket72 10/22/2012 10:29:48 AM(UTC)
Replacement Cooktop Burner (Oven Repair (including Ranges and Cooktops))
by Butzing 6/21/2012 8:23:18 AM(UTC)
Cooktop burner gets stuck on - does not cycle (Oven Repair (including Ranges and Cooktops))
by ottmeister 2/4/2012 9:49:18 AM(UTC)
Frigidaire cooktop burner not shutting off (Oven Repair (including Ranges and Cooktops))
by eldon_brasche 6/30/2011 10:17:49 AM(UTC)
Cooktop burners/parts -- Possibly Roper (Oven Repair (including Ranges and Cooktops))
by keyjo50 6/10/2011 3:12:53 PM(UTC)
Cooktop burners on when they shouldn't be (Oven Repair (including Ranges and Cooktops))
by 440@gmx.us 4/1/2011 5:09:08 PM(UTC)
