I have a Frigidaire cooktop model fec32s6hba and the right side expandable burner keeps sticking in the on position. This occurs randomly after it has been used. If you turn off the switch, it stays on and you have to turn it off and on several times to get it to go off. Any ideas?
Most likely the problem is a bad switch for this burner. If this is the right front dual burner then the switch Part number: AP3775555
gene i have the same problem just a bigger unit.. fec36s8hsa the back left and the front right burner are not working with the light remaining on all the time what parts should i order...?
Originally Posted by: jplowe61  gene i have the same problem just a bigger unit.. fec36s8hsa the back left and the front right burner are not working with the light remaining on all the time what parts should i order...? If other burners are fine, very likely the problem is a bad switches for these burners. Because both of these burners are dual, the switches are identical. - The infinite switch Part number: AP3775555
