i have a glass top Kenmore range with radiant heating. The 9" burner stopped working. The wires were burnt when i looked at it. I ordered a new burner on line it is a replacement and has a different wiring schematic. I am looking for a wiring diagram for this model.
The wiring diagram could be inside the control panel or under the top panel. If it's not there then you can order it from Sears. The Sears part number is SR13606.
