ARRABITOT
#1 Posted : Friday, October 19, 2007 4:41:02 PM(UTC)
ARRABITOT
The dryer will start but shuts off in 10 seconds. I removed the belt to see if the drum was putting any drag on the motor. The motor spins freeely by hand, but when starting it runs then stops in 10 seconds.
Jesus Gutierrez
#2 Posted : Friday, October 19, 2007 6:06:12 PM(UTC)
Jesus Gutierrez
The motor is pulling high amperage and over load is opening. Could be the age of motor or motor needs a good cleaning.
#3 Posted : Saturday, October 20, 2007 1:37:45 AM(UTC)
Sounds like a stuck centrifical switch on the motor. Check for motor high current like over 10 amps. Callappliancepartspros, they may have one for your dryer.
Maytag Dryer blinking lights won't start (Dryer Repair)
by LRP116 Today at 6:25:54 AM(UTC)
Maytag Dryer Panel Lights Work But Won't Start (Dryer Repair)
by G-Daddy 10/31/2018 4:37:11 PM(UTC)
A Maytag dryer, how to hook up a replacement motor? (Dryer Repair)
by Mark531 8/4/2018 11:44:35 AM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
Maytag Dryer Burnt Black Wire to Heating Element (Dryer Repair)
by jvaklh6194 3/11/2018 12:18:12 PM(UTC)
Brand new Maytag dryer won't work (Dryer Repair)
by Dave_H 2/16/2018 8:31:32 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
How do I disassemble Maytag dryer? (Dryer Repair)
by Cnyle 11/9/2017 6:40:12 PM(UTC)
Maytag Dryer Issue (Dryer Repair)
by Erik42 11/7/2017 4:19:03 PM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
put Maytag dryer together after a repair but have one piece left (Dryer Repair)
by 2harts4ever 10/2/2017 3:06:13 AM(UTC)
Maytag dryer noise (Dryer Repair)
by Cmjb13 9/7/2017 7:20:37 PM(UTC)
Maytag Dryer short cycling burner (Dryer Repair)
by g12196 8/25/2017 8:09:43 AM(UTC)
Maytag Dryer snags clothes (Dryer Repair)
by NormV 8/14/2017 5:35:42 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
