I just rebuilt the pump on this machine and now I am getting almost no water flow into the washer. I checked the float, fill valve and timer for continuity, and they all showed it, but don't have a wiring diagram to check for open circuits. Any ideas? thanks
Originally Posted by: jojosdad  I just rebuilt the pump on this machine and now I am getting almost no water flow into the washer. I checked the float, fill valve and timer for continuity, and they all showed it, but don't have a wiring diagram to check for open circuits. Any ideas? thanks JoJosDad, Your post indicates you most likely wont find a problem in the wiring or circuits, You have a slow fill, not a no fill situation. You have debris built up on the filter screen or flow washer, inside the valve body. You can dismantle the fill valve(remove the screws that mount the plastic valve housing to the metal mounting bracket) clean the debris from the screen, and check the flow washer. You also want to "flush" the water supply line to the valve before you re attach it to the valve connection. were it me, I would just replace the valve assembly, a little less work, with a more positive effect. Part number: AP2039339
But that's up to you. Good Luck, :) :) :)
