jojosdad
#1 Posted : Monday, March 7, 2011 3:51:18 PM(UTC)
jojosdad
I just rebuilt the pump on this machine and now I am getting almost no water flow into the washer. I checked the float, fill valve and timer for continuity, and they all showed it, but don't have a wiring diagram to check for open circuits.
Any ideas?
thanks
Joe / APP Team
#2 Posted : Tuesday, March 8, 2011 11:37:24 AM(UTC)
Joe / APP Team
Any ideas?
thanks
JoJosDad,
Your post indicates you most likely wont find a problem in the wiring or circuits,
You have a slow fill, not a no fill situation.
You have debris built up on the filter screen or flow washer, inside the valve body.
You can dismantle the fill valve(remove the screws that mount the plastic valve housing to the metal mounting bracket) clean the debris from the screen, and check the flow washer.
You also want to "flush" the water supply line to the valve before you
re attach it to the valve connection.
were it me, I would just replace the valve assembly, a little less work, with a more positive effect.
Part number: AP2039339
But that's up to you.
Good Luck,
filling problems (Washer Repair)
by jmneil 12/15/2014 9:31:58 AM(UTC)
washing machine filling problems. (Washer Repair)
by jbhew 3/24/2011 1:03:40 PM(UTC)
Filling problem (Dishwasher Repair)
by jojosdad 9/30/2010 11:22:48 AM(UTC)
water filling problem (Washer Repair)
by jrice01 1/12/2010 6:47:54 PM(UTC)
filling problem HELP!!!! (Washer Repair)
by sunnymoonjumper 7/28/2009 9:42:10 AM(UTC)
Water filling problem (Washer Repair)
by Doug L 4/6/2009 11:47:49 AM(UTC)
Overfilling problem (Washer Repair)
by gosportbound 3/5/2009 1:00:57 PM(UTC)
