jojosdad
#1 Posted : Thursday, September 30, 2010 11:22:48 AM(UTC)
jojosdad
I have a GE dishwasher that has almost no water coming in - just a little trickle out of the arms. Is there a screen in the water valve that can be cleaned?
#2 Posted : Thursday, September 30, 2010 11:28:01 AM(UTC)
[COLOR="Blue"]Is there a screen in the water valve that can be cleaned?[/COLOR]
Yes on the input side of the valve.
Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
jojosdad
#3 Posted : Thursday, September 30, 2010 3:03:45 PM(UTC)
jojosdad
OK - checked it out and it's clean. Does anyone have the specs for the water valve electronics?
#4 Posted : Thursday, September 30, 2010 4:55:32 PM(UTC)
Check that the valve is getting 120 volts when it is supposed to.
If OK
Check that the plumbing path from the valve to the machine tub is clear.
If OK
Odds are good that replacing the valve will solve your perblem.
Also would not hurt to check that there is good water flow to the machine.
Most dishwasher hookups have a shuy off valve in the water line check that someone has not turned it partially off by mistake.
jojosdad
#5 Posted : Monday, October 11, 2010 2:35:47 PM(UTC)
jojosdad
Thanks for the help - I replaced the valve (it was getting 120 volts and not working), and it fixed the problem.
If OK
If OK
#6 Posted : Saturday, October 16, 2010 1:19:40 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
filling problems (Washer Repair)
by jmneil 12/15/2014 9:31:58 AM(UTC)
washing machine filling problems. (Washer Repair)
by jbhew 3/24/2011 1:03:40 PM(UTC)
Filling problem (Dishwasher Repair)
by jojosdad 3/7/2011 3:51:18 PM(UTC)
water filling problem (Washer Repair)
by jrice01 1/12/2010 6:47:54 PM(UTC)
filling problem HELP!!!! (Washer Repair)
by sunnymoonjumper 7/28/2009 9:42:10 AM(UTC)
Water filling problem (Washer Repair)
by Doug L 4/6/2009 11:47:49 AM(UTC)
Overfilling problem (Washer Repair)
by gosportbound 3/5/2009 1:00:57 PM(UTC)
