Beau
#1 Posted : Thursday, December 25, 2008 8:15:02 PM(UTC)
Beau
I have a side by side whirlpool refrigerator and the ice maker has stopped as well. I have switched the valves and the hoses and have found that the valves both are working. The door switch did allow water to flow into the ice maker, so the valve was working fine. When I opened the freezer door I pushed the flap on the left side and observed the flashing light stop and remained on, but did not flash.My first thought was could it be the sender or the receiver or is there another switch somewhere like with the cold water dispenser. What could the problem be, maybe the ice tray and ice dispenser. Is there some way to test the sender and receiver with an ommeter.
Thanks for any info
Beau
#2 Posted : Friday, December 26, 2008 12:13:05 PM(UTC)
Hi Beau,
If the LED stays "on" then the problem is a bad ice maker. Unfortunately there is no on-line access to Australian models and/or parts list. You have to contact a local distributor.
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Frige 2014 no Ice & frige is 50 degrees (Refrigerator & Freezer Repair)
by Plus160 7/5/2023 5:05:07 PM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
GE Cafe Refrigerator No Ice (Refrigerator & Freezer Repair)
by amappliancewi 2/8/2023 5:22:22 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
No Icecream at night - Freezer stops cooling around 8PM and everything is Frozen by 8AM. - (Refrigerator & Freezer Repair)
by usercraig 3/7/2022 7:40:11 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
Samsung RS265TDRS Not Cooling/No Ice (Refrigerator & Freezer Repair)
by Guest 5/31/2021 10:09:58 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
** RESOLVED ** Subzero 590, no ice (Refrigerator & Freezer Repair)
by Intel1919 9/12/2020 9:54:24 AM(UTC)
