rrosales
#1 Posted : Tuesday, December 23, 2008 3:46:00 PM(UTC)
rrosales
dryer wont start, ligth is on, power in the outlet is good I already buy the thermal fuse kit and replaced and still nothing. what else can be wrong:confused:
#2 Posted : Wednesday, December 24, 2008 1:42:34 AM(UTC)
Here is your parts breakdown includes a wiring diagram
Model PYET344AYW
By not start I assume you mean the motor will not start.
Also that the light you refer to is the interior light.
If it hums then it is a different problem than below.
The next thing to check is the DOOR SWITCH.
Manually actuate the switch so the light goes off and try to start.
If the light does not go off then the switch is no good.
This does not eliminate the switch totally because it may open the light contacts but not close the door closed contacts.
Your circuit path to start the motor is:
NEUTRAL / THERMAL FUSE / DOOR SWITCH N.O. CONTACTS / MOTOR both aux & run windings get power / PUSH TO START SWITCH / TIMER CONTACTS L&M / L1
kayakcrzy
#3 Posted : Wednesday, December 24, 2008 4:04:09 AM(UTC)
kayakcrzy
You could either have a bad door switch, or, the breaker might be tripped. Tom
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
