dryer wont start, ligth is on, power in the outlet is good I already buy the thermal fuse kit and replaced and still nothing. what else can be wrong:confused:
Here is your parts breakdown includes a wiring diagram Model PYET344AYWBy not start I assume you mean the motor will not start. Also that the light you refer to is the interior light. If it hums then it is a different problem than below. The next thing to check is the DOOR SWITCH. Manually actuate the switch so the light goes off and try to start. If the light does not go off then the switch is no good. This does not eliminate the switch totally because it may open the light contacts but not close the door closed contacts. Your circuit path to start the motor is: NEUTRAL / THERMAL FUSE / DOOR SWITCH N.O. CONTACTS / MOTOR both aux & run windings get power / PUSH TO START SWITCH / TIMER CONTACTS L&M / L1 |
THIS FORUM IS DEAD!!!!!!! |
You could either have a bad door switch, or, the breaker might be tripped. Tom
