joseph duncan
#1 Posted : Monday, December 15, 2008 11:21:58 AM(UTC)
joseph duncan
The door on my sub-zero refrigerator doesn't seem to want to close completely. Where it used to take a little effort to pull the door open, it now will almost open itself. The freezer side is fine. Do I need to replace the door seal or could the problem be caused by something else?
#2 Posted : Tuesday, December 16, 2008 11:15:19 AM(UTC)
Most likely the problem is a bad door closer (on the bottom of the door). You have to call Sub-Zero (888-506-9513) to order the part.
Refrigerator door does not automatically close (Refrigerator & Freezer Repair)
by smateja@earthlink.net 11/10/2016 1:04:22 PM(UTC)
Advice on replacing Monogram refrigerator door gasket (Refrigerator & Freezer Repair)
by TerryY 10/14/2016 6:30:50 PM(UTC)
Refrigerator door seal (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:57:27 PM(UTC)
Refrigerator door makes popping sound when opening and closing (Refrigerator & Freezer Repair)
by johnschwery 5/22/2015 8:27:41 AM(UTC)
GE Refrigerator door keeps hitting light switch (Refrigerator & Freezer Repair)
by pnorris411 11/2/2014 3:44:45 PM(UTC)
exterior of panel between the frezzer door and the refrigerator door is burning hot (Refrigerator & Freezer Repair)
by splash13 7/19/2014 7:44:36 PM(UTC)
Frigidare Refrigerator door handle loose (Refrigerator & Freezer Repair)
by dojoy 2/19/2014 1:53:04 PM(UTC)
Refrigerator Door Handle Loose (Refrigerator & Freezer Repair)
by Lauren57 10/30/2013 7:29:50 PM(UTC)
Frigidaire Refrigerator Door Sagging (Refrigerator & Freezer Repair)
by supermoose 4/5/2013 10:49:33 AM(UTC)
how to remove refrigerator door handle (Refrigerator & Freezer Repair)
by srace 1/6/2013 5:16:15 PM(UTC)
Maytag French Door Refrigerator Doors Not Staying Closed (Refrigerator & Freezer Repair)
by davej14 10/29/2012 6:59:55 AM(UTC)
no water from refrigerator door (Refrigerator & Freezer Repair)
by mike glazer 9/18/2012 6:50:51 PM(UTC)
Refrigerator door not closing tightly (Refrigerator & Freezer Repair)
by Lery 8/18/2012 12:18:40 PM(UTC)
refrigerator door seal (Refrigerator & Freezer Repair)
by Pablito Dos 8/12/2012 6:34:42 AM(UTC)
Refrigerator Door stop broken (Refrigerator & Freezer Repair)
by TheDickens 8/7/2012 11:04:56 AM(UTC)
