srace
#1 Posted : Sunday, January 6, 2013 5:16:15 PM(UTC)
srace
Just purchased new door and realize I need to remove the door handle from old door and put onto new door. Looks like there are 2 set screws (allen wrench to remove?), but not obvious how to remove once set screws are out.
Also, can I reuse the old door seal?, old door got scrathed up, works fine, but needed to replace due to scratches.
#2 Posted : Monday, January 7, 2013 3:49:54 AM(UTC)
Parts for Frigidaire LGUS2642LF1 Refrigerator - AppliancePartsPros.com
Take a look at the Refrigerator Door Parts section items 80 and 18.
If you click on the items picture a new page will open with better views.
Looks like it should just pull off once the set screws clear the shoulder screw groove.
You should be able to reuse the old door seal as long as it is in good shape.
