joseph duncan
#1 Posted : 16 years ago
joseph duncan
The door on my sub-zero refrigerator doesn't seem to want to close completely. Where it used to take a little effort to pull the door open, it now will almost open itself. The freezer side is fine. Do I need to replace the door seal or could the problem be caused by something else?
#2 Posted : 16 years ago
Most likely the problem is a bad door closer (on the bottom of the door). You have to call Sub-Zero (888-506-9513) to order the part.
Refrigerator door does not automatically close (Refrigerator & Freezer Repair)
by smateja@earthlink.net 8 years ago
Advice on replacing Monogram refrigerator door gasket (Refrigerator & Freezer Repair)
by TerryY 8 years ago
Refrigerator door seal (Refrigerator & Freezer Repair)
by chknmom 9 years ago
Refrigerator door makes popping sound when opening and closing (Refrigerator & Freezer Repair)
by johnschwery 10 years ago
GE Refrigerator door keeps hitting light switch (Refrigerator & Freezer Repair)
by pnorris411 10 years ago
exterior of panel between the frezzer door and the refrigerator door is burning hot (Refrigerator & Freezer Repair)
by splash13 11 years ago
Frigidare Refrigerator door handle loose (Refrigerator & Freezer Repair)
by dojoy 11 years ago
Refrigerator Door Handle Loose (Refrigerator & Freezer Repair)
by Lauren57 11 years ago
Frigidaire Refrigerator Door Sagging (Refrigerator & Freezer Repair)
by supermoose 12 years ago
how to remove refrigerator door handle (Refrigerator & Freezer Repair)
by srace 12 years ago
Maytag French Door Refrigerator Doors Not Staying Closed (Refrigerator & Freezer Repair)
by davej14 12 years ago
no water from refrigerator door (Refrigerator & Freezer Repair)
by mike glazer 12 years ago
Refrigerator door not closing tightly (Refrigerator & Freezer Repair)
by Lery 13 years ago
refrigerator door seal (Refrigerator & Freezer Repair)
by Pablito Dos 13 years ago
Refrigerator Door stop broken (Refrigerator & Freezer Repair)
by TheDickens 13 years ago
