tjg1234562003
#1 Posted : Friday, February 4, 2011 1:53:44 PM(UTC)
tjg1234562003
I don't get ant heat from my dryer anymore. Any help as to what is the problem. Heating element?Fuses?Thermostat?
#2 Posted : Saturday, February 5, 2011 12:14:42 AM(UTC)
Replacement parts for WHIRLPOOL WED5800SW0 29``ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
[COLOR="DarkRed"]Heating element?Fuses?Thermostat?[/COLOR]
Could be any of these plus a couple other things.
Note: the thermal fuse for the heater is Item 9 in Section 3 (thermal cut-off).
If it is blown then there are other things you should check before replacing it.
The one on the blower is for the motor.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater circuit requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
WED5800.pdf (259kb) downloaded 6 time(s).
kayakcrzy
#3 Posted : Saturday, February 5, 2011 1:40:52 AM(UTC)
kayakcrzy
It is usually either the thermal cutt of switch, or the element. Unplug the dryer, and take the big back panel off. The element is on the right bottom. There is a few 1/4 inch screws to remove it, on each side of the element housing. The thermal limit switch is on the top left side of the heater housing. It has 2 wires coming to it. If you have an ohm meter, pull the 2 wires off of the thermal limit switch, and check for continuity. If you have any reading it is good. Do the same to the element. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
