Replacement parts for WHIRLPOOL WED5800SW0 29``ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the wiring diagram
[COLOR="DarkRed"]Heating element?Fuses?Thermostat?[/COLOR]
Could be any of these plus a couple other things.
Note: the thermal fuse for the heater is Item 9 in Section 3 (thermal cut-off).
If it is blown then there are other things you should check before replacing it.
The one on the blower is for the motor.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater circuit requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
