Hello, I am trying to change thermostat P/N 3387134 in my Whirlpool Dryer. One of the terminal is marked with "X" and I don't know if solid red wire is the right one to be attached to it or red with white stripe on it. Please advice substandard mechanic
As far as I know it should not make a difference as it is AC and these are the cycling contacts.
Sorry for the double post. |
THIS FORUM IS DEAD!!!!!!! |
The X is probably there just to tell you that the connections are the contacts and not the internal heater. |
