I have replaced heating element(Broken wire) and both drum & element thermostat and still have no heat. :( Where do I go from here???
I am assuming that the dryer does run.
Check the power. The dryer motor etc requires 120 volts but the heating coil needs the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. [COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
Not going to be an electrical conductor :eek: ...Electrician coming out Friday. Thanks for the tip, will re-post after electrician diagnosis.
