jvjgolfnut
#1 Posted : Wednesday, December 15, 2010 5:03:53 AM(UTC)
jvjgolfnut
I have replaced heating element(Broken wire) and both drum & element thermostat and still have no heat. :( Where do I go from here???
#2 Posted : Wednesday, December 15, 2010 6:22:26 AM(UTC)
I am assuming that the dryer does run.
Check the power. The dryer motor etc requires 120 volts but the heating coil needs the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
jvjgolfnut
#3 Posted : Wednesday, December 15, 2010 6:20:54 PM(UTC)
jvjgolfnut
Not going to be an electrical conductor :eek: ...Electrician coming out Friday. Thanks for the tip, will re-post after electrician diagnosis.
