substandard mechanic
#1 Posted : Thursday, February 3, 2011 4:33:15 PM(UTC)
Hello,
I am trying to change thermostat P/N 3387134 in my Whirlpool Dryer.
One of the terminal is marked with "X" and I don't know if solid red wire is the right one to be attached to it or red with white stripe on it.
Please advice
#2 Posted : Friday, February 4, 2011 1:25:34 AM(UTC)
As far as I know it should not make a difference as it is AC and these are the cycling contacts.
Sorry for the double post.
#3 Posted : Friday, February 4, 2011 1:26:41 AM(UTC)
The X is probably there just to tell you that the connections are the contacts and not the internal heater.
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
No heat, so tested thermostats, now dryer won't even start (Dryer Repair)
by ccauthe 6/17/2014 4:26:40 AM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Dryer won't start. Changed all thermostats and fuse (Dryer Repair)
by rudekelly 4/23/2014 6:55:22 PM(UTC)
New Element , New Thermostats Too? (Dryer Repair)
by kprovost10 1/4/2014 4:47:48 PM(UTC)
no heat, thermostats good (Dryer Repair)
by deadchef 12/26/2013 5:51:08 PM(UTC)
aloha from Hawaii/ thermal fuse blown/ red wires burnt to two thermostats now (Dryer Repair)
by nature boy 7/27/2013 1:30:49 AM(UTC)
New Defrost thermostats not responding (Refrigerator & Freezer Repair)
by Mojo21 7/5/2013 1:13:31 PM(UTC)
New element, thermostats good, No heat (Dryer Repair)
by Taylor8 1/13/2013 3:25:17 PM(UTC)
Thermostats (Oven Repair (including Ranges and Cooktops))
by dd willow 12/14/2012 9:50:30 AM(UTC)
Thermostats (Dryer Repair)
by gjose15 1/22/2012 9:45:24 PM(UTC)
checking dryer thermostats (Dryer Repair)
by shields 3/28/2011 3:37:54 PM(UTC)
electric whirl pool dryer electrical surge after replacing thermostats (Dryer Repair)
by reame 1/2/2011 12:26:43 PM(UTC)
No heat after replacing element & thermostats (Dryer Repair)
by jvjgolfnut 12/15/2010 5:03:53 AM(UTC)
