gjose15
#1 Posted : Sunday, January 22, 2012 9:45:24 PM(UTC)
gjose15
Im trying to fix my electric dryer but Im not sure how to check if the thermostats work. I have a multimeter and if I can use that please tell me how. Also what can be other problems with my dryer if it wont heat up it just turns on and does everything else but heat up and dry clothes. :confused:
ApplianceJunk
#2 Posted : Monday, January 23, 2012 4:18:13 AM(UTC)
ApplianceJunk
I have a collection of dryer videos at this URL that you may find helpful.
Your thermal cut-off could be at fault or you could have a bad heating element.
http://appliancejunk.com...s/index.php?topic=9049.0
Also be sure to check the voltage to your dryer.
How do I check the voltage to my electric dryer?
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
No heat, so tested thermostats, now dryer won't even start (Dryer Repair)
by ccauthe 6/17/2014 4:26:40 AM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Dryer won't start. Changed all thermostats and fuse (Dryer Repair)
by rudekelly 4/23/2014 6:55:22 PM(UTC)
New Element , New Thermostats Too? (Dryer Repair)
by kprovost10 1/4/2014 4:47:48 PM(UTC)
no heat, thermostats good (Dryer Repair)
by deadchef 12/26/2013 5:51:08 PM(UTC)
aloha from Hawaii/ thermal fuse blown/ red wires burnt to two thermostats now (Dryer Repair)
by nature boy 7/27/2013 1:30:49 AM(UTC)
New Defrost thermostats not responding (Refrigerator & Freezer Repair)
by Mojo21 7/5/2013 1:13:31 PM(UTC)
New element, thermostats good, No heat (Dryer Repair)
by Taylor8 1/13/2013 3:25:17 PM(UTC)
Thermostats (Oven Repair (including Ranges and Cooktops))
by dd willow 12/14/2012 9:50:30 AM(UTC)
checking dryer thermostats (Dryer Repair)
by shields 3/28/2011 3:37:54 PM(UTC)
by substandard mechanic 2/3/2011 4:33:15 PM(UTC)
electric whirl pool dryer electrical surge after replacing thermostats (Dryer Repair)
by reame 1/2/2011 12:26:43 PM(UTC)
No heat after replacing element & thermostats (Dryer Repair)
by jvjgolfnut 12/15/2010 5:03:53 AM(UTC)
