Question: I have a roper dryer that is 3 years old. When I turn it on the dryer gets hot at first; however then it cuts off. The clothes get warm but not enough to dry them. The feel hot and damp when I open the dryer up after the cycle is finished. What could be the problem??? :confused:
I would try the following.
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems |
THIS FORUM IS DEAD!!!!!!! |
