rurede4m
#1 Posted : Friday, January 28, 2011 9:17:34 AM(UTC)
rurede4m
My whirlpool is intermittently cooling. When it works, it works fine. But after a day or so everything will melted. I replaced the thermostat and it does the same thing. Water is dripping from the top of the refridgerator and is filling up the bottom until it leaks out. A few times I was able to turn the thermostat to off, wiat a few seconds and turn it back on. It would work fine after that - but that doesn't always work. When it does't work, I do see the lights inside go a little dim as if something kicks in. From the formums I'm thinking this has something to do with the defrost cycle. Does that sound correct?
#2 Posted : Friday, January 28, 2011 11:20:13 AM(UTC)
You might have a compressor going sour. Next time it fails, remove the back panel and see if the compressor is trying to start. If so, you just might have a bad compressor. If the compressor is running, the small diameter tubing from it will be hot and the compressor will be humming/vibrating.
Intermittent cooling and then heating up of fresh and freezer (Refrigerator & Freezer Repair)
by AGBecker 6/1/2021 7:16:01 PM(UTC)
Intermittent Cooling (Refrigerator & Freezer Repair)
by F47 3/26/2015 5:20:35 AM(UTC)
intermittent cooling (Refrigerator & Freezer Repair)
by mandrew 2/8/2015 7:18:36 AM(UTC)
GE Side By Side Intermittent Cooling (Refrigerator & Freezer Repair)
by dtoppin 9/9/2014 8:41:40 PM(UTC)
Intermittent cooling (Refrigerator & Freezer Repair)
by 68 TWind 9/6/2014 1:17:58 PM(UTC)
Intermittent Cooling Failure (Refrigerator & Freezer Repair)
by Mike4069 4/23/2014 10:29:20 AM(UTC)
Fridge and Freezer intermittent cooling issues (Refrigerator & Freezer Repair)
by mojojojo 4/18/2014 5:25:25 PM(UTC)
by raceshonda 11/4/2013 8:26:56 AM(UTC)
by Dsimon 12/11/2012 1:30:23 PM(UTC)
Intermittent Cooling Issues (Refrigerator & Freezer Repair)
by jondurst 6/6/2011 8:50:31 AM(UTC)
GE Refrigerator Intermittent Cooling Issues - Help! (Refrigerator & Freezer Repair)
by ucbedge 9/12/2010 3:49:09 PM(UTC)
Carrier AC Intermittent Cooling (Heating, Ventilation, and Air Conditioning (HVAC))
by loowens 8/18/2009 5:58:58 AM(UTC)
intermittent Cooling GE (Refrigerator & Freezer Repair)
by bobp 8/14/2007 4:58:34 PM(UTC)
