Noticed a week or two ago that the refirgerator was not as cool as normal (was about 45-50 degrees). Setting was at the middle cooling setting for refrig and freezer. Turned refrig one one setting colder and compressor kicked on and it returned to normal temp. Went out of town and got a call that the ice in ice maker had thawed and ran out the ice chute onto the floor. Instructed caller to turn freezer and refrigerator dials to coldest. Got home a day later and everything was fine. Next day, temp in refrig was warmer. Moderately cold air was blowing out of vent. Can hear compressor running and hear fan in freezer running, but compressor doesn't seem to turn off. Where should I start looking for the problem? Evaporator coil?
Measure the freezer and fridg. temperatures and post.
Originally Posted by: richappy Measure the freezer and fridg. temperatures and post. The freezer has settings for A, B, C, and coldest and the refrigerator has settings from 0 to 5. Temp in freezer last night at coldest setting=10.0 Freezer last night at C setting=16.2 Freezer this morning at C setting=23.2 Temp in refrigerator last night at 4.5 setting=40.8 Last night at 4.0 (warmer setting than 4.5 setting=45.3 This morning still at 4.0 setting=52.2
Freezer temperatures are too warm. assuming The evaporator coils are free of heavy frost, check the condenser coils for lint clog, if ok, you probably have a refrigerant leak/ bad compressor.
