biziswinning
#1 Posted : Friday, January 21, 2011 6:37:13 PM(UTC)
biziswinning
Hello, my dryer is not heating. I took out the back cover and took the part where the coils are and i don't know what the problem is..I know it's got something to do with this part, but it also has a few small parts attached to it in which i took out the wires in able to get it completely out of the dryer..I use to help my father fix these things but i don't have the equipment to diagnose...Is it the small switches attached or is it the coils inside this metal part?
#2 Posted : Sunday, January 23, 2011 4:07:06 AM(UTC)
A model number may help others help you.
The first thing to check is the power.
The motor uses half the line (120 volts) while the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
kayakcrzy
#3 Posted : Sunday, January 23, 2011 6:11:51 AM(UTC)
kayakcrzy
How do the coils look since you pulled them out? Do you see a break? If not, it will most likely be the part on the top left side of the heater housing. It is called the thermal limit switch. If you had a meter, check and see if there is any continuity on the element, and the thermal limit switch. Pull 1 wire off, each part when you check it. If there is no reading, that is the part that is bad. Tom ApplianceEducator.com
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Whirlpool Dryer Not Heating (Dryer Repair)
by Frustrated42 11/8/2015 7:21:05 AM(UTC)
by handygirl67 3/12/2015 1:14:03 PM(UTC)
whirlpool dryer not heating nor timer advancing (Dryer Repair)
by bladrnr 12/26/2013 12:39:41 PM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool Dryer not heating (Dryer Repair)
by cindystarr 9/28/2012 2:57:39 PM(UTC)
Whirlpool dryer not heating or turning (Dryer Repair)
by splumer 9/22/2012 10:05:44 AM(UTC)
by ValpoMan 9/17/2012 3:34:11 PM(UTC)
by rdmousaw 8/7/2012 1:03:50 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by Phiphtie 1/4/2012 3:09:19 PM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
