MariaHoewischer
#1 Posted : Monday, December 1, 2008 11:58:00 AM(UTC)
MariaHoewischer
My dryer will turn on and heat!! Sometimes it will do a whole load, but most of the time it will only dry a couple of minutes and then shut off, but will turn right back on when i push the button and do the same thing again!!! The vent it clear and clean, i broomed of the back of dryer. Made loads smaller still dueing the same thing!?!?!
#2 Posted : Tuesday, December 2, 2008 1:45:30 AM(UTC)
Model RED4440SQ0
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528190.pdf
You do not have to worry about the heater section (thermostats etc.), they will not shut the motor off which is what I think is happening
Could be a number of things:
1. Motor overheating - The motor has a built in thermal protect/cutoff that opens if the motor overheats but this takes a couple minutes for the motor to cool down for it to reset so from your description of re-starting it is low on the list.
2. Door switch - Could be it is just making, the clothes hit the door, the switch opens and the dryer stops. Bend the switch actuator a little so that it actuates more positively when the door closes. Be careful you do not want to break the actuator.
3. Start relay - Could be weak or have pitted contacts and is dropping out during a cycle. I do not know how you would check this other than replacing it. If bad, sometimes you can hear them buzz but not always.
4. A bad timer contact
5. A loose wire - Low in probability but a possibility
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 4/19/2020 3:58:45 PM(UTC)
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
roper dryer (Dryer Repair)
by smoke-71 3/3/2015 3:56:21 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
