Ron S
#1 Posted : 16 years ago
Ron S
My gas dryer will not heat up but the drum will turn. no lint and the vent is clear.
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
Take a look and see if the glow coil comes on. If not, take the back off the dryer, and you will see a part about an inch and a half long, by a half inch wide, and it is white in color. That is the thermal fuse. Make sure the dryer is unplugged, and take the 2 wires off the thermal fuse, and put the terminal ends together, and put a little tape on it, so it does not hit metal, and then see if it works. If it does, DO NOT RUN the dryer that way. That thermal fuse is the only thing stopping that dryer from burning down the house. If it does not work it will either be the ignitor or the flame sensor. Tom ApplianceEducator.com
paul armbruster
#3 Posted : 16 years ago
paul armbruster
I have a Kenmore dryer with the same symptom and used your troubleshooting tip to fix it. Thank you. Paul A.
dirtguy150
#4 Posted : 16 years ago
dirtguy150
I had the same exact problem and it seems my thermal fuse was bad also. I'm off to order one right away. Thanks for the help!!!!
kayakcrzy
#5 Posted : 16 years ago
kayakcrzy
Glad to help both of you. Tom ApplianceEducator.com
padronman01
#6 Posted : 14 years ago
padronman01
I taped the wires, and poof, there was my flame. Thank you. Now, hopefully I can get the part...
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10 years ago
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 11 years ago
Gas dryer will not heat (Dryer Repair)
by PhilWi 12 years ago
Maytag gas dryer will not heat (Dryer Repair)
by jsweeyor 12 years ago
GE gas dryer will not heat (Dryer Repair)
by kthorson 12 years ago
by RickWilliams 14 years ago
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 15 years ago
Kenmore gas dryer will not heat (Dryer Repair)
by mcclr 15 years ago
by sch8891 15 years ago
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 16 years ago
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 17 years ago
by retcop320 17 years ago
maytag gas dryer will not heat after initial burn (Dryer Repair)
by Agustin 17 years ago
