Ron S
#1 Posted : Sunday, November 30, 2008 1:28:06 PM(UTC)
Ron S
My gas dryer will not heat up but the drum will turn. no lint and the vent is clear.
kayakcrzy
#2 Posted : Monday, December 1, 2008 4:14:18 AM(UTC)
kayakcrzy
Take a look and see if the glow coil comes on. If not, take the back off the dryer, and you will see a part about an inch and a half long, by a half inch wide, and it is white in color. That is the thermal fuse. Make sure the dryer is unplugged, and take the 2 wires off the thermal fuse, and put the terminal ends together, and put a little tape on it, so it does not hit metal, and then see if it works. If it does, DO NOT RUN the dryer that way. That thermal fuse is the only thing stopping that dryer from burning down the house. If it does not work it will either be the ignitor or the flame sensor. Tom ApplianceEducator.com
paul armbruster
#3 Posted : Wednesday, December 3, 2008 8:11:21 PM(UTC)
paul armbruster
I have a Kenmore dryer with the same symptom and used your troubleshooting tip to fix it. Thank you. Paul A.
dirtguy150
#4 Posted : Sunday, January 18, 2009 1:21:23 PM(UTC)
dirtguy150
I had the same exact problem and it seems my thermal fuse was bad also. I'm off to order one right away. Thanks for the help!!!!
kayakcrzy
#5 Posted : Sunday, January 18, 2009 1:51:00 PM(UTC)
kayakcrzy
Glad to help both of you. Tom ApplianceEducator.com
padronman01
#6 Posted : Saturday, August 21, 2010 11:47:09 AM(UTC)
padronman01
I taped the wires, and poof, there was my flame. Thank you. Now, hopefully I can get the part...
Guest (4)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Gas dryer will not heat (Dryer Repair)
by PhilWi 10/19/2012 12:50:42 PM(UTC)
Maytag gas dryer will not heat (Dryer Repair)
by jsweeyor 10/2/2012 12:15:23 PM(UTC)
GE gas dryer will not heat (Dryer Repair)
by kthorson 9/27/2012 4:30:00 AM(UTC)
by RickWilliams 10/25/2010 11:45:37 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore gas dryer will not heat (Dryer Repair)
by mcclr 10/24/2009 5:51:31 PM(UTC)
by sch8891 10/13/2009 8:26:20 AM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
Whirlpool gas dryer will not heat. (Dryer Repair)
by brae 11/22/2007 5:52:59 AM(UTC)
by retcop320 9/11/2007 3:18:41 PM(UTC)
maytag gas dryer will not heat after initial burn (Dryer Repair)
by Agustin 8/27/2007 3:21:24 PM(UTC)
