krysten2
#1 Posted : Thursday, November 27, 2008 7:30:03 PM(UTC)
krysten2
Ok, washer is not draining, it will fill and agitate and spin but will not drain. Replaced the timer, that's not the problem. Lid switch closes, washer goes through cycle, I watch the lid lock come on and off. Not sure what else it could be. Undid the pump, no blocks anywhere. Undid the wire conneted to the pump - not getting any power, hooked up 110 to it and it pumped. Where is the problem????? Can't find any burnt wires anywhere, although it does smell a little by the motor...any help would be great, thanks!
libertyappl
#2 Posted : Friday, November 28, 2008 3:31:59 AM(UTC)
libertyappl
Most likely your pump is out.
Nat
krysten2
#3 Posted : Friday, November 28, 2008 7:07:26 AM(UTC)
krysten2
But the pump worked when I hooked up power to it?????
libertyappl
#4 Posted : Friday, November 28, 2008 7:41:15 AM(UTC)
libertyappl
There maybe a loose wire in the harness going to the pump.
Nat
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
