My Ge Profile Dryer Squeaks And It Leaves Rust Colored Marks On The Clothes. Help!!!!!
clothes are wedging in the fron between the drom and the drum support. replace the felt
If your dryer is like mine, there are a couple nylon or teflon bearing plates that the drum rides on that are on the inside of the front panel. You will most likely need to replace the back bearings too if this has been happening for a while. Mine had eaten through the nylon bushing and metal guide. After I replaced all of this the dryer worked flawlessly. No noise or stained clothes.
Good luck.
:cool:
