abldr
#1 Posted : Thursday, November 4, 2010 1:19:56 PM(UTC)
abldr
Freezer is too cold (-9), tried adjusting at digital in-door panel, unit cycles off at +9, set at 4 but it resets itself to -9 at exit? Assuming temperature adjustment board is bad?
#2 Posted : Friday, November 5, 2010 1:26:12 AM(UTC)
If you have a meter, check the freezer thermistor AP3185407 located on the bottom, left of the freezer, should be around 5k ohm at room temperature.
You can also measure it at the motherboard in the back, J1 connector, pins J5 to J3
old maytag mtb1895 freezer too cold (Refrigerator & Freezer Repair)
by Guest 1/26/2022 8:49:08 PM(UTC)
Frigidaire FFHS2611PF, freezer too cold (Refrigerator & Freezer Repair)
by rleary78@gmail.com 1/26/2021 8:04:49 AM(UTC)
Compressor loud, runs constantly. Fridge/freezer too cold (Refrigerator & Freezer Repair)
by Plasticspaceman 4/15/2020 8:23:37 PM(UTC)
Freezer too cold, Ice build up causing leak (Refrigerator & Freezer Repair)
by Sgibb16 4/23/2018 9:12:33 PM(UTC)
Refrigerator too warm, Freezer too cold (Refrigerator & Freezer Repair)
by scm518 7/7/2015 4:40:12 AM(UTC)
Freezer too cold & refrigerator too warm (Refrigerator & Freezer Repair)
by dbdata 6/2/2015 5:00:32 PM(UTC)
GE Monogram 36" bottom freezer refrigerator - Freezer too cold @ -9 / Fridge at 44*F (Refrigerator & Freezer Repair)
by vfdfs2 8/17/2014 3:10:17 PM(UTC)
GE Profile freezer too cold, fridge seems okay (Refrigerator & Freezer Repair)
by chrispitude 12/29/2013 2:45:51 PM(UTC)
Fridge too warm, freezer too cold (Refrigerator & Freezer Repair)
by worstcase 10/20/2012 10:01:35 AM(UTC)
Freezer too cold/icing and everything shuts down (Refrigerator & Freezer Repair)
by LaurenG 10/15/2012 12:55:23 PM(UTC)
Fridge warm, freezer too cold and frosting (Refrigerator & Freezer Repair)
by Voltar 7/5/2012 6:15:57 PM(UTC)
Freezer Too Cold, Fridge Too Warm.... (Refrigerator & Freezer Repair)
by dcoates 5/3/2012 9:16:19 AM(UTC)
Freezer too cold? (Refrigerator & Freezer Repair)
by skipdog77 2/1/2012 6:16:42 PM(UTC)
GE Profile freezer too cold, fridge too warm (Refrigerator & Freezer Repair)
by angpoon 1/4/2012 12:41:09 PM(UTC)
Freezer too cold, refrigerator too warm (Refrigerator & Freezer Repair)
by bandm59yakima 9/4/2011 1:31:28 PM(UTC)
