Freezer is too cold (-9), tried adjusting at digital in-door panel, unit cycles off at +9, set at 4 but it resets itself to -9 at exit? Assuming temperature adjustment board is bad?
If you have a meter, check the freezer thermistor AP3185407 located on the bottom, left of the freezer, should be around 5k ohm at room temperature. You can also measure it at the motherboard in the back, J1 connector, pins J5 to J3
old maytag mtb1895 freezer too cold
(Refrigerator & Freezer Repair)
by Guest
1/26/2022 8:49:08 PM(UTC)
Frigidaire FFHS2611PF, freezer too cold
by rleary78@gmail.com
1/26/2021 8:04:49 AM(UTC)
Compressor loud, runs constantly. Fridge/freezer too cold
by Plasticspaceman
4/15/2020 8:23:37 PM(UTC)
Freezer too cold, Ice build up causing leak
by Sgibb16
4/23/2018 9:12:33 PM(UTC)
Refrigerator too warm, Freezer too cold
by scm518
7/7/2015 4:40:12 AM(UTC)
Freezer too cold & refrigerator too warm
by dbdata
6/2/2015 5:00:32 PM(UTC)
GE Monogram 36" bottom freezer refrigerator - Freezer too cold @ -9 / Fridge at 44*F
by vfdfs2
8/17/2014 3:10:17 PM(UTC)
GE Profile freezer too cold, fridge seems okay
by chrispitude
12/29/2013 2:45:51 PM(UTC)
Fridge too warm, freezer too cold
by worstcase
10/20/2012 10:01:35 AM(UTC)
Freezer too cold/icing and everything shuts down
by LaurenG
10/15/2012 12:55:23 PM(UTC)
Fridge warm, freezer too cold and frosting
by Voltar
7/5/2012 6:15:57 PM(UTC)
Freezer Too Cold, Fridge Too Warm....
by dcoates
5/3/2012 9:16:19 AM(UTC)
Freezer too cold?
by skipdog77
2/1/2012 6:16:42 PM(UTC)
GE Profile freezer too cold, fridge too warm
by angpoon
1/4/2012 12:41:09 PM(UTC)
Freezer too cold, refrigerator too warm
by bandm59yakima
9/4/2011 1:31:28 PM(UTC)
