timjmix11
#1 Posted : Tuesday, October 5, 2010 6:04:45 PM(UTC)
timjmix11
I have a GE electric dryer that won't stay running. When I turn the start button the motor runs but as soon as I let go of the switch the dryer shuts off. I have replaced the motor and it still runs the same. Could it be the actual start switch? Thanks.
#2 Posted : Thursday, October 7, 2010 2:13:33 AM(UTC)
Replacement parts for General Electric DWSR483EB0WW Electric dryer | AppliancePartsPros.com
I would doubt is as it is opening and closing.
I see on in the parts that the unit has a belt switch (Item 803 in Section 1).
I cannot get a wiring diagram for this particular unit so am doing a bit of guessing. Following is one way GE wires in this switch, as you can see it is in the start/run centrifugal switch path and so would stop the unit from running after the start switch is released.
Perhaps the switch is shot or is not being activated for some reason.
http://www.applianceaid.com/newimages/ge-newelec-diagram.JPG
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Dryer won't stay running after replacing parts (Dryer Repair)
by dlg56 11/6/2016 6:54:36 PM(UTC)
Dryer won't stay running... (Dryer Repair)
by Charlie.2loose@gmail.com 7/26/2015 7:29:52 AM(UTC)
Whirlpool Gold dryer won't stay running and no heat (Dryer Repair)
by swami69 4/7/2014 10:15:38 AM(UTC)
Dryer won't stay running (Dryer Repair)
by White72gs455 12/24/2013 1:19:55 PM(UTC)
Admiral Dryer Won't Stay Running (Dryer Repair)
by ravynfire 10/16/2012 6:51:07 AM(UTC)
by OKFREE 4/23/2011 7:35:37 AM(UTC)
by JimRumler 1/31/2011 11:28:26 AM(UTC)
by hollyparrish 1/26/2011 7:35:43 AM(UTC)
Dryer won't stay running. (Dryer Repair)
by nwpop05 1/13/2010 2:21:38 PM(UTC)
by MONA SMITH 11/15/2009 7:19:33 PM(UTC)
by Fixitchick 9/24/2009 4:12:27 PM(UTC)
by teetwofalcon 8/8/2009 3:34:19 AM(UTC)
GE Electric Dryer won't stay running (Dryer Repair)
by bdrg 1/8/2009 8:09:06 AM(UTC)
Bosch dryer won't stay running - sometimes (Dryer Repair)
by jhabetler 3/2/2008 1:17:47 PM(UTC)
