Oven will not light Broiler and stovetop work fine Suggestions?
The most common problem would be the ignitor using a clamp on amp meter to one lead of the ignitor it should draw 3.2-3.6 amps if not replace it. if it doesn't glow at all its bad if it glows some it may not be pulling enough amps to open the valve
Just to add my 2 cents... Agreed with v2k04. Most likely the problem is a bad igniter. - The part number for the igniter is AP205873 Gene.
