My oven will not light. The cooktop works and the broiler below works but not the oven. Stays at 100 degrees. Whats the problem and part? New ignitor????
Originally Posted by: mikenpd133  My oven will not light. The cooktop works and the broiler below works but not the oven. Stays at 100 degrees. Whats the problem and part? New ignitor???? Mike, Very good, Yes you most likely have a weak oven igniter. Part number: AP4012072
If the igniter does not draw 3.2 to 3.6 amps or produce 3.2 to 3.6 VAC to the oven safety valve terminals, the valve will not open and release the gas for ignition. A weak igniter can glow but not open the valve. Thanks and Good Luck, :) :) :)
