oven will not light most ofthe time. some times if you slam the broiler door it will light. The ignitor is glowing red but the gas is not coming on. I tried to replace the clock/timer, this did not correct the problem. Is the safety valve bad, or is it possible that the ignitor resistance is not correct for the valve to open?
Groups: APP Team
Hi. To determine if the ignitor is bad you need a clamp on amp-meter.Put the clamp around one ignitor's wire and turn the oven on. If it reed less than 3.2 amp - replace the ignitor. The ignitor Part number: AP2150412
