ACummings
#1 Posted : Tuesday, March 27, 2012 1:51:01 PM(UTC)
ACummings
oven will not light most ofthe time. some times if you slam the broiler door it will light. The ignitor is glowing red but the gas is not coming on. I tried to replace the clock/timer, this did not correct the problem. Is the safety valve bad, or is it possible that the ignitor resistance is not correct for the valve to open?
Simon / APP Team
#2 Posted : Tuesday, March 27, 2012 4:13:00 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
To determine if the ignitor is bad you need a clamp on amp-meter.Put the clamp around one ignitor's wire and turn the oven on.
If it reed less than 3.2 amp - replace the ignitor.
The ignitor Part number: AP2150412
Here are the breakdown diagrams and Replacement parts for Frigidaire FGF337AWE Frigidaire/gas Range | AppliancePartsPros.com
Good luck. Post the results.
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
by PatY 8/16/2010 6:34:08 PM(UTC)
