2 Pages12>
gypsyqueen
#1 Posted : Thursday, May 24, 2012 8:50:45 AM(UTC)
gypsyqueen
My son has a frigidaire gas stove and suddenly the oven will not light. The gas flows fine and the rest of the stove works. He is a disabled vet so not able to get down there and check it so I had a look and I think it has an electronic ignition but not sure. Could that be the case and is it an easy enough job to replace that I might be able to do it for him? I have repaired my dryer and washer before so I do have a little experience but not an expert.Thank you for any help you can provide, Morgan
Simon / APP Team
#2 Posted : Thursday, May 24, 2012 10:08:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The most common problem is bad oven ignitor. Use the multimeter to check the ignitor's continuity. If it's open or glow red - replace it.
The ignitor Part number: 5303935066
Here are breakdown diagram and Burner replacement parts for Frigidaire FGF326ASE Frigidaire/gas Range | AppliancePartsPros.com
If the ignitor checks good then you need to check the gas valve and the control board.Let me know if you'll need more help.
Thank you. Post the results.
Simon.
gypsyqueen
#3 Posted : Thursday, May 24, 2012 10:38:26 AM(UTC)
gypsyqueen
Ok, I spoke to him few minutes ago and I know that the broiler doesnt work as well. I have a multimeter but I hate to admit that I am not sure how to use it :( I know, typical female right? lol So if I can figure out how to use it I would check for 120v reading? If it is the Igniter, is it easy to replace? Sorry for all the questions but one can't learn if one doesn't ask.
Thank you soooo much for your help, Morgan
Simon / APP Team
#4 Posted : Thursday, May 24, 2012 11:08:10 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can ask any questions. I'll do my best to answer. With the oven set for bake check for 120VAC going to the ignitor. If you are getting 120V - replace the ignitor.
If no voltage - unplug the unit and check the oven gas valve for continuity.If it's open - replace it.
The gas valve Part number: 3203459
The ignitor is held by two screws and should not be a problem to replace.
Post the results and questions.
Simon.
gypsyqueen
#5 Posted : Thursday, May 24, 2012 11:21:11 AM(UTC)
gypsyqueen
Thanks so much for info and I will post back results. It may be a day or 2 depending on when I can get over to where he is located but I will post back.
Again, thank you, Morgan
gypsyqueen
#6 Posted : Friday, June 22, 2012 10:01:57 AM(UTC)
gypsyqueen
Sorryittook so long to get backwith you but had an accident and broke my clavicle.:( Oven waschecked out before I got to it and was told it is the control module. Is that a difficult repair? Thank you for being patient with me and for your help
Simon / APP Team
#7 Posted : Friday, June 22, 2012 10:20:03 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can gain the access to the control module by pulling the range out and taking off the control panel rear cover.
Do not forget to unplug the unit.
Thank you.
Simon.
gypsyqueen
#8 Posted : Friday, June 22, 2012 10:24:09 AM(UTC)
gypsyqueen
Is the part expensive? Sounds like it shouldnt be to challenging to put on, evenwith broken body parts lol
Simon / APP Team
#9 Posted : Friday, June 22, 2012 10:39:07 AM(UTC)
Simon / APP Team
Groups: APP Team
Here are you parts Part number: 316455410
Overlay Part number: 316220700
Thank you.
Simon.
gypsyqueen
#10 Posted : Friday, June 22, 2012 10:50:06 AM(UTC)
gypsyqueen
So I take it I need both parts? I just noticed while checking the parts link, so the control module is actually the clock/timer? Lol, why dont they just say that the timer is out? It is an 'oven' not a spaceship after all.
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
by PatY 8/16/2010 6:34:08 PM(UTC)
2 Pages12>
