mikenpd133
#1 Posted : Thursday, October 6, 2011 6:30:33 AM(UTC)
mikenpd133
My oven will not light. The cooktop works and the broiler below works but not the oven. Stays at 100 degrees. Whats the problem and part? New ignitor????
Joe / APP Team
#2 Posted : Thursday, October 6, 2011 12:09:20 PM(UTC)
Joe / APP Team
Mike,
Very good, Yes you most likely have a weak oven igniter.
Part number: AP4012072
If the igniter does not draw 3.2 to 3.6 amps or produce 3.2 to 3.6 VAC to the oven safety valve terminals, the valve will not open and release the gas for ignition. A weak igniter can glow but not open the valve.
Thanks and Good Luck,
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
by PatY 8/16/2010 6:34:08 PM(UTC)
