rdk
#1 Posted : Tuesday, October 14, 2008 10:02:55 AM(UTC)
rdk
Oven will not light
Broiler and stovetop work fine
Suggestions?
v2k04
#2 Posted : Tuesday, October 14, 2008 10:14:38 AM(UTC)
v2k04
The most common problem would be the ignitor using a clamp on amp meter to one lead of the ignitor it should draw 3.2-3.6 amps if not replace it. if it doesn't glow at all its bad if it glows some it may not be pulling enough amps to open the valve
#3 Posted : Wednesday, October 15, 2008 8:59:14 AM(UTC)
Just to add my 2 cents...
Agreed with v2k04. Most likely the problem is a bad igniter.
- The part number for the igniter is AP205873
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
