Scott Taylor
#1 Posted : Thursday, September 25, 2008 7:29:01 AM(UTC)
Scott Taylor
3 weeks ago freezer stopped working, ice tray meelted creating a sheet of ice along back and side wall. Unplugged and defrosted, plugged back in and worked fine for 2 weeks until same thing happened, ice melting in bucket. Tech came out and said evap. motor was bad. Took all food out of freezer and unit kicked on again later same night. Tech showed up next day to replace motor and noticed freezer working fine, now says it is main board, replaces board but now turbo cool light does not shut off only changes from bright green to slightly dimmer which has been the case for 3 weeks since defrosting the first time. Could it just be the display or will my freezer go out again in 2 weeks?
libertyappl
#2 Posted : Thursday, September 25, 2008 7:48:08 AM(UTC)
libertyappl
That sounds like a defrsot issue, which is controlled y the main control board on the back.
Nat
Frigidaire Gallery Fridge issues (Dishwasher Repair)
by Guest 6/5/2023 3:03:07 PM(UTC)
fridge issues (Refrigerator & Freezer Repair)
by e4g76 6/28/2017 4:12:50 PM(UTC)
frdge issues (Refrigerator & Freezer Repair)
by ctpiper 7/12/2013 8:47:28 AM(UTC)
Jenn Aire S136 cartridge issues (Oven Repair (including Ranges and Cooktops))
by son in law repairman 2/4/2013 9:38:30 PM(UTC)
Range issues (Oven Repair (including Ranges and Cooktops))
by kdarge 1/2/2013 11:50:35 AM(UTC)
GE Fridge issues (Refrigerator & Freezer Repair)
by honnat 10/9/2010 10:59:40 AM(UTC)
Amana electric range issues (Oven Repair (including Ranges and Cooktops))
by tdjtorkelson 2/26/2010 9:30:56 AM(UTC)
GE Spectra Glass Top Range issues.. (Oven Repair (including Ranges and Cooktops))
by CarlaPhi 4/6/2009 7:46:48 AM(UTC)
Gas range issues (Oven Repair (including Ranges and Cooktops))
by merntim 10/29/2008 12:10:34 PM(UTC)
Gas Range Issues (Oven Repair (including Ranges and Cooktops))
by norsemanc 12/5/2007 5:04:34 PM(UTC)
