kdarge
#1 Posted : Wednesday, January 2, 2013 11:50:35 AM(UTC)
kdarge
I have a Kitchen aid glass top range that on Thanksgiving day decided not to cook to its full potential. Range top works but the oven says it is heated up to a certain temp but will not cook food like it should everything ends up under cooked. Cakes etc. not done through out. where to start? It apears that my oven has a double element at the top and they both glo orange when turned on. what next?
#2 Posted : Thursday, January 3, 2013 1:05:17 AM(UTC)
Parts for Whirlpool KERC507HBS3 Range - AppliancePartsPros.com
When in preheat and bake do the upper and lower elements cycle.
This is the norm as it gives a faster preheat and during bake a more consistent temperature profile in the oven.
Could be that the bake element is bad.
Could be a problem with the oven sensor if the elements do cycle.
Below is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
May also be a bad oven timer/control board.
You may want to get a oven thermometer so you can check the actual oven temperature. Most units will let you calibrate the oven plus or minus 35 degrees.
File Attachment(s):
KERC507.pdf (145kb) downloaded 5 time(s).
Amana electric range issues (Oven Repair (including Ranges and Cooktops))
by tdjtorkelson 2/26/2010 9:30:56 AM(UTC)
GE Spectra Glass Top Range issues.. (Oven Repair (including Ranges and Cooktops))
by CarlaPhi 4/6/2009 7:46:48 AM(UTC)
Gas range issues (Oven Repair (including Ranges and Cooktops))
by merntim 10/29/2008 12:10:34 PM(UTC)
Gas Range Issues (Oven Repair (including Ranges and Cooktops))
by norsemanc 12/5/2007 5:04:34 PM(UTC)
