gorden
#1 Posted : 15 years ago
gorden
Two inches of ice sitting in the bottom of the freezer, some of it thaws, leaks onto the floor. the freezer freezes food very hard and i cant turn it down. whats my fridges problem?
#2 Posted : 15 years ago
The ice on the freezer floor means the drain under the evaporator in the freezer is clogged and/or frozen.
Remove the rear panel in the freezer and defrost the drain, using a hair dryer. Run hot water through the drain to make sure it's open. A turkey baster might help. Pool the refrigerator out of the wall and make sure the other end of the drain is open as well. It is a good time to clean the condenser.
Wait about 24 hours after it's done and measure the temperature in both compartments. Post the results.
gorden
#3 Posted : 15 years ago
gorden
Glen, you nailed it.
somehow the little tin tray that catches the run off water got bent, instead of the water running through the down spout a good part of it was running down the side collecting at the bottom of the freezer.
The down spout that runs to the collection tray was clogged as well.
I dragged my little compressor in and blew everything out. I took your advice and gave it the turkey baster test. everything over the last 24hours seems to be in order.
I have the freezer on 1. the lowest setting and it seems to me like its too cold??? I don't have a thermometer to read the temp.
Thanks for the assistance, i'm sure you saved me the service call. :)
#4 Posted : 15 years ago
You are welcome. I'm glad you were able to fix it.
Any ice cream in the freezer is a good temperature indicator. If it's not too hard or too soft, the temperature is fine.
inqfinance
#5 Posted : 15 years ago
inqfinance
I have the same issue. When you say the evaporator coil, where do I find it and also, where do I find the defroster?
What is turkey baster?
#6 Posted : 15 years ago
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 about a year ago
Kenmore Side by Side Warm (Refrigerator & Freezer Repair)
by Lery 5 years ago
Kenmore side by side ice maker problem (Refrigerator & Freezer Repair)
by DIY987 6 years ago
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 6 years ago
1970's Kenmore Side by side...constantly running (Refrigerator & Freezer Repair)
by silvering 8 years ago
Kenmore Side by Side Freezer Leaking (Refrigerator & Freezer Repair)
by rkirkwo1 8 years ago
Kenmore Side by Side Frost Buildup (Refrigerator & Freezer Repair)
by metolius22 10 years ago
Kenmore Side By Side Fridge Warm Freezer Good (Refrigerator & Freezer Repair)
by craig72 10 years ago
Kenmore side by side won't get cold (Refrigerator & Freezer Repair)
by hprambo 11 years ago
kenmore side by side not defrosting (Refrigerator & Freezer Repair)
by john 10512 11 years ago
Kenmore side by side freezing food (Refrigerator & Freezer Repair)
by Felony 11 years ago
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11 years ago
Kenmore side by side freezer not freezing (Refrigerator & Freezer Repair)
by Handy handy 12 years ago
Kenmore side by side freezing up (Refrigerator & Freezer Repair)
by BaileyH 12 years ago
Kenmore side by side (Refrigerator & Freezer Repair)
by Rtazz17 12 years ago
