DIY987
#1 Posted : 5 years ago
DIY987
Hi
Looking for some help in diagnosing my problem
I have a Kenmore side by side fridge from around 2010. The ice maker is not working
I’ve changed the ice maker unit and both sensors on either side of the freezer door.
However, it’s still not working
When the freezer door is open the red light flashes twice then pauses then flashes twice again.
When I depress the flap on the left hand side the red light stays solid
From what I’ve read this seems to be normal
I turned off the fridge for a couple of hours to see if defrosting would remove any ice blockage from the supply pipe into the ice maker but no change
The water supply to the water dispenser is working fine
Suggestions?
